Siebel Order Management Infrastructure Guide > Copy Service > Copy Service Methods >
SetFieldValueFromInstance Method
The method sets the field value to an instance. Arguments
- InstanceName: [in] ISS business component instance name
- FieldName: [in] business component field name
- BusCompName: [in] Used to specify a business component other than the instance business component, if necessary. (Optional)
- FieldValue: [in] Field value.
- GetLOVValue: [in] LOV Type. If defined, the FieldValue is the LOV language-independent code. The actual field value will be the language-dependent display value as defined by LOV Type/Language independent code. (Optional)
