Siebel Order Management Infrastructure Guide > Copy Service > Copy Service Methods >
Copy Method
The method copies the source instance to the destination instance based on the defined copy map. Arguments
- SourceInstance: [in] Source instance name.
- DestinationInstance: [in] Destination instance name.
- MapName: [in] Data map name.
- CachedUpdate: [in] Y or N. Performance option to allow for cached updates. All SQL generated in the operation is issued to the database in one batch. Therefore, a SQL in the block cannot depend on a previous SQL being committed to the database. (Optional)
- Release: [in] Source/Destination/All. If defined, the corresponding instance(s) is popped up and released after the operation. (Optional)
