Siebel Order Management Infrastructure Guide > Other Component Business Services for C/OM > ISS Credit Check Service >
SetCreditCheckResults Method
This method writes the credit status data to the database. If the credit status is empty, it is set to indeterminate. Arguments
- Credit Status As Of: [in] The date that the status is valid.
- Credit Status Code: [in] The status code. A number from 1 to 6 or a value pre-LOV lookup (such as Okay or Indeterminate).
- Credit Status Message: [in] A string describing credit status.
- Id: [in] The ID of the quote or order.
- Return Error: [in] A flag that, when set to N, the function will return an OK regardless.
