Siebel Order Management Infrastructure Guide > Other Component Business Services for C/OM > ISS Promotion CP Admin ServiceThe ISS Promotion CP Admin business service allows you to add more constraints for a customizable product (CP) when the CP is covered by a promotion. In the process of defining a promotion, you can change cardinality or add more domain and attribute constraints for a CP when the CP is covered by a promotion rule. At run time, the constraints will be checked against the CP when it is covered by the promotion. The CP constraints are cached along with the promotion definition. NOTE: When you make changes to the CP constraints under a promotion, you must clear the cached promotion information. |
Siebel Order Management Infrastructure Guide | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
