Siebel Order Management Infrastructure Guide > Other Component Business Services for C/OM > ISS ATP Service >
CSSISSFulfillmentService::ATPRunCheck Method
This method provides a business service wrapper function for ATP ASIs. Arguments
- Id: [in] The header ID for the quote or order.
- Line Item Id: [in] If inquire at line level is called, this contains the line ID. If inquire all is called, then this is empty.
- Inbound Integration Object: [in] The inbound internal integration object should be quote-specific or order-specific. This is used for database write.
- Outbound Integration Object: [in] The outbound internal integration object should be quote-specific or order-specific. This is used for database query.
- ATPAction: [in] The action to be specified at the line level: such as Inquire, Reserve, and so on.
Example Arguments
["ATP Action"] = "Inquire"; ["Outbound Integration Object"] = "ATP Check Interface Request - Orders"; ["Inbound Integration Object"] = "ATP Check Interface Response - Orders"; ["Id"] = "99-2AICU"; ["Line Item Id"] = "42-4ZBY1"; ["Outbound Integration Object1"] = "ATP Check Interface Request - Orders"; ["Inbound Integration Object1"] = "ATP Check Interface Response - Orders";
