Siebel Order Management Infrastructure Guide > Variable Maps > Using Variable Maps >
Creating Variable Maps
You create and modify variable maps in the Variable Maps views of the run-time client. To implement a new variable map
- Navigate to the Administration - Order Management screen, then Variable Maps view.
- In the Variable Maps list, create a new record.
- Give the variable map a name.
- Lock the variable map by checking the Locked Flag field.
This locks the object for your user ID.
- In the Versions list, click the Work Space hyperlink to drill down on the variable map version.
- Click the Modes tab to access the Modes view.
- In the Modes list, define the variable map modes.
- Click the Details tab and create variable definitions and variable maps.
- In the Variable Definitions list, you can define the list of variables in the variable map. These names are independent of the source.
- The In/Out field defines whether the variable map can update the variable.
- In the Variable Sources list, you can define the source of the variable for each mode.
- Define child variable maps, as necessary.
- Navigate back to the Variable Maps list, and click the Release New Version button to release the variable map version.
- Test the variable map in the run-time client by executing a reprice or another PSP procedure.
- Using Application Deployment Manager (ADM), promote the updated signal definition to the production environment.
For more information about ADM, see Siebel Application Deployment Manager Guide.
Use the following procedure to update an existing variable map. To update an existing variable map
- Select the variable map and lock it by checking the Locked Flag field.
- Modify the variables as necessary.
- Navigate back to the Variable Maps list and click the Release New Version button to release the variable map version.
- Using Application Deployment Manager, promote the updated signal definition to the production environment.
Use the following procedure to configure a custom Mode user property for a driving business component. To configure a custom Mode user property for the driving business component
- On the business component that raises the signal, set the Mode user property.
- In the Variable Maps screen, Modes view, declare the new mode for one or more variable maps.
- Define variable sources for the mode.
