| Siebel Partner Relationship Management Administration Guide > Managing Partner Commerce >  Removing the PRM Portal Shopping Cart Toolbar
 The standard method of removing toolbars is not used for removing the Shopping Cart toolbar from the Siebel PRM Portal. This section gives high-level instructions for removing this toolbar. You should do this only if you are experienced at working with Siebel Tools. For more information, see Siebel Tools Reference. To remove the PRM Portal shopping cart toolbar
In Siebel Tools, navigate to:
Web Page = eChannel Container Page Web Page Item = Shopping CartSet Inactive = TRUE.
