Siebel Partner Relationship Management Administration Guide > Managing Your Partners > Certifying Your Partners >
Associating Certifications with a Partner Company
You can create a certification record for each of your partners and associate these records with certification templates. You can also set up Siebel Business Process Designer to automatically enter the value Certified in the Status field of the Certification record when values are filled in the Certification Criteria list that satisfy all the requirements of the certification, making the partner company a certified partner. For more information about Siebel Business Process Designer, see Siebel Business Process Designer Administration Guide. To create a certification record and associate it with a partner
- Navigate to the Partners screen.
- In the Partners list, select the partner company for which you want to create a certification.
- Click the Certifications view tab.
Certifications view appears.
- In the Certifications applet, click the menu button, and then click New Record.
- Enter information from the following table in the fields.
Template Name |
Click the select button and select a predefined template. The criteria in the Certification Criteria applet are automatically filled based on the template chosen. |
Certification Name |
Enter a name for the certification. |
Description |
Enter a description of the certification. |
Partner |
Enter the name of the partner company. |
Active |
This field is automatically set to true if the End Date is greater than today. |
Status |
Indicates the status of the certification—In Progress, Not Started, Certified. |
Certified Date |
The date on which the status is set to Certified is entered automatically when you select this status. |
End Date |
The end date is entered automatically, set based on the certified date and the validity (in months) defined for the certification template. |
