| Siebel Partner Relationship Management Administration Guide > Managing Your Partners > Certifying Your Partners > Checking a Partner's Progress
 At any time, you can look up each certification a partner company is working on and how much progress has been made on each one.  To look up a partner company's certifications
Navigate to the Partners screen.
In the Partners list, select the partner company whose certifications you want to check.
Click the Certifications view tab.
Certification view appears.Select any certification record in the Certifications list.
The criteria for that certification are displayed in the Certification Criteria list.  In the Certification Criteria list, compare the Target#, Target Amount, or Condition Clause field for each record with the Actual#, Actual Amount, or Condition Met field for each record. |
