Siebel Partner Relationship Management Administration Guide > Managing Your Partners > Certifying Your Partners > Configuring Autopopulation of Partner Certification CriteriaWhen the user adds a Certification child record to a Partner record in the Partner Certification - Certifications Detail view of the Partners screen, the criteria associated with the template selected are automatically populated in the Certification Criteria applet. This autopopulation depends on the following user properties in the Partner Certification business component: Autopopulation also requires that the following business components are configured in the Channel Partner business object using the appropriate links:
The user properties and the business components must be consistent. |
| Siebel Partner Relationship Management Administration Guide |
