Siebel Partner Relationship Management Administration Guide > Managing Your Partners > Tracking Partner Information > Entering Partner AgreementsIt is often useful to have a list of the agreements that you have made with a partner company to refer to when you want to look up a specific agreement. Use the Partner Agreements view to record the agreements that you have made with your partners. For more information on agreements, see the chapter on agreements in Applications Administration Guide. NOTE: The partner agreements that appear in the Partners screen should not be confused with service agreements with your customers. Partner agreements are agreements between the brand owner and partner company. |
| Siebel Partner Relationship Management Administration Guide |
