Siebel Partner Relationship Management Administration Guide > Partner-to-Partner Collaboration > Siebel ProjectsSiebel Projects is a virtual work space that allows direct partner-to-partner collaboration among employees of different partner companies. Partners can use it to work together on software deployment, installation of equipment, sales opportunities that require involvement of multiple partners, and many other types of projects. All partner employees who are part of the project can view information associated with the project, so employees of different partner companies can use the project to share information and work together. The brand owner also has visibility across all projects on which the partners are working. Brand owners can monitor the status of the project based on project time lines, project budget, and key risk areas. For more information about Siebel Projects, see Siebel Professional Services Automation Guide. The following is a scenario that describes how a partner that specializes in deploying software applications uses Siebel Projects to work with a partner that specializes in hardware. Because these partners are part of the same project, they can share information and work collaboratively on the project. This scenario has the following steps:
Step 1. The Partner Creates a New ProjectIn the example used in this scenario, a partner company that specializes in implementation has won a contract to deploy the brand owner's software. This partner uses the Siebel PRM Portal to create a project, which it can use to work with the brand owners and with other partners.
Step 2. The Partner Locates Other Partners and Adds Them to this ProjectThe partner company that created the project realizes that it will need the help of a partner that specializes in hardware to work on this project. The partner can locate appropriate partners and add them to the project in two different ways:
When they use the Partner Locator, partners can find appropriate companies by searching based on expertise, location, and other criteria. In this case, the partner would enter a criterion such as Partner Type = Hardware. After the initiating partner has found the appropriate partner to work with, the two partners can initiate a collaboration. Assuming the hardware partner accepts the collaboration, the initiating partner can add the hardware partner to the project team. Alternatively, they can request the brand owner to add the hardware partner to the project team using the All Projects Across Organizations view in Siebel PRM Manager.
Step 3. Partners Add Their Employees to the ProjectOnce the partner companies that need to be involved in a project have been added to the project, each partner company can add its own employees as users of the project. These users form the virtual project team. NOTE: All partner companies in the project must add their own employees to the project, to allow those employees to access information about the project. To add partner employees to the project
Step 4. The Partners Work Together on the ProjectAll of the partner employees who have been added to the project can use the Siebel PRM Portal to view information about the project, such as the project summary, and to add information to the project, such as activities, contacts, invoices, notes, risks, service requests, status reports, tasks, and other information. Any partner employee who is on the project can see the information that the other partners have added. To add or view information about the project
Step 5. The Brand Owner Tracks the Partners' WorkThe brand owner can view the project to track its progress, even though the project was set up by partners independent of the brand owner. The brand owner can view all projects, even if it has not explicitly been made a member. To track the partners' work on the project
| Siebel Partner Relationship Management Administration Guide |
