Siebel Partner Relationship Management Administration Guide > Partner Programs Administration > About Application Approval > Reviewing Application Detail Inbox InformationApplication Inbox views show all program applications submitted by registered partners. Prospective and qualified partners can apply for partner programs but their applications will not appear in these views until they are registered. For information on registering a partner, see Enrollment Process. This task is a step in the Process for Approving an Application. Use the following procedure to view application detail information. To view application detail information (brand owner)
Reviewing Application DetailThe Application Detail view shows the program applications with the corresponding responses from the partner. These question/answer pairs can be in one of these two formats: Smartscript Session: For questions where the Save Answer Table is checked. For more information on Smartscript, see Siebel SmartScript Administration Guide. External Application: If membership applications are delivered using .jsp or .asp pages, the PPR Partner Program Application Detail Integration Component within the PPR Partner Program Integration Object must be used for mapping and integration. This task is a step in the Process for Approving an Application. Use the following procedure to view application information. To view the application detail information (brand owner)
Reviewing Application AttachmentsThe Attachments view is where that attachments that the partner has uploaded appear. This task is a step in Process for Approving an Application. Use the following procedure to review attachments associated with the application. To view the application attachments (brand owner)
Reviewing Application ActivitiesBrand owner and partner users can monitor the activities associated with approving an application. These activities fields can be populated based on an activity plan associated to the partner program. This task is a step in the Process for Approving an Application. Use the following procedure to review activities associated with the application. To view the application activities
Reviewing the Application Audit TrailUpdates to fields such as Status and Partner Names can be tracked in the Audit Trail. This step is a task in the Process for Approving an Application. Use the following procedure to view the audit trail. To view the application audit trail (brand owner)
Reviewing Application MDF ProgramsWhen the partner's application status is Approved, all MDF programs that are associated to the partner program appear in the MDF Program view. The brand owner can also generate new MDF program accounts for the partner from this view as needed. This task is a step in the Process for Approving an Application. NOTE: The following procedure applies to the Advanced MFD option only. For more information, see Managing the Advanced MDF Option. To view MDF programs associated with the application (brand owner) |
| Siebel Partner Relationship Management Administration Guide |
