Siebel Partner Relationship Management Administration Guide > Partner Programs Administration > About Application Approval >
Rejecting an Application
If the application should not be approved, you can reject it by clicking the Reject button on the Application Inbox. Use the following procedure to reject an application. To reject an application (brand owner)
- Navigate to Partner Programs screen > Application Inbox link.
- Select the application and click Reject.
The message, Are you sure you would like to reject this application?, appears. Click Yes.
The Status field is Rejected.
