Siebel Partner Relationship Management Administration Guide > Setting Up Application Services Interfaces > Setting Up ASIs > General Setup for ASIsTo set up either opportunity transfer or shopping cart transfer, in addition to the tasks described previously, you must also perform the tasks in this section: Activate WorkflowsFor either opportunity transfer or shopping cart transfer, you must activate the workflow processes used for real-time integration. NOTE: For testing, you must do this on the second system as well.
Assigning D-U-N-S NumbersFor either opportunity transfer or shopping cart transfer, you must enter a D-U-N-S number for your own company and for all partner companies that will use ASIs. The ASIs use the D-U-N-S number to uniquely identify the companies that are sending and receiving information. Though it is recommended that you use the D-U-N-S number, you can use any unique identification number that you and your partners agree on. NOTE: You should also assign D-U-N-S numbers for Accounts that you transfer back and forth to make sure both systems are referring to the same account. Alternatively, you can change the inbound workflows to search for the Account Name instead of the D-U-N-S number when checking to see if the Account already exists.
NOTE: The D-U-N-S numbers that your partners use must match the D-U-N-S numbers you use. The D-U-N-S number you enter for a partner in your system must match the D-U-N-S number that partner uses for itself in its system. The D-U-N-S number you enter for your own company in your own system must match the number the partner uses for your company in its system. |
| Siebel Partner Relationship Management Administration Guide |
