Siebel Partner Relationship Management Administration Guide > Sharing Data with Partners > Sharing Master Data with Partners > Creating Categories and Access GroupsBefore partner managers assign any master data to partner companies, the channel operations manager or system administrator must analyze the way you need to share master data with your partners and create the appropriate categories and access groups. Though most of the work of setting up catalogs and access groups is done when you first set up Siebel PRM, you can add catalogs and access groups to the application at any time. Some examples of when you would add them are as follows:
You would also want to continuously add information to catalogs as more data is created and made available. For example, you would need frequent updates to catalogs as you create new FAQs and new product data sheets or brochures. For more information on creating categories and access groups, see Setting Up Siebel PRM. |
| Siebel Partner Relationship Management Administration Guide |
