Performance Tuning Guide > Tuning Siebel Workflow for Performance > Tuning Workflow Policies for Performance >
Running Workflow Agents on Multiple Siebel Servers
You can run Workflow Agent processes on different Siebel Servers to ease the workload on each Siebel Server. You can then adjust the polling interval for each group so that polling for noncritical policies does not prevent efficient processing of critical policies. By distributing workflow policy processes across Siebel Servers:
- High-maintenance policies can be grouped on a Siebel Server with sufficient resources to handle the workflow CPU requirements.
- Low-maintenance policies can be run on a Siebel Server that shares resources with other Siebel processes.
