Siebel Remote and Replication Manager Administration Guide > Administering Siebel Remote > How to Set Client-Side Logging >
Event Levels
Users set the type of information to be collected by temporarily changing the environment variable SIEBEL_LOG_EVENTS. To temporarily change the environment variable SIEBEL_LOG_EVENTS
- Open a DOS Window and change the current directory to the
<ClientRootDir>\bin directory.
- Enter the following command:
set SIEBEL_LOG_EVENTS=<event level>
NOTE: <event level> can be between 0 and 5. Higher levels collect more detailed information and use more disk space. With the default value of 1, minimal information is collected in the trace file. Set event level to 3 or higher to troubleshoot a problem, or if assistance is required from Siebel Technical Support.
When setting to the higher levels, check that sufficient disk space to is available.
- Launch the Siebel client application with the appropriate parameter from the same DOS Window.
For example, to launch the Siebel application with user=USERNAME, password=PASSWORD, and CFG (name and path of the CFG file), and then to log in to local database, enter:
siebel /u USERNAME /p PASSWORD /c CFG/ d local
This environment variable can also be changed permanently. To do this, follow the procedures below. To permanently change environment variable SIEBEL_LOG_EVENTS in Win2000
- In the Windows Start menu, choose Settings > Control Panel > System > Advanced Environment Variables.
- Click New and enter the following fields:
Variable Name = SIEBEL_LOG_EVENTS
Variable Value = <event level>
- Click OK.
The newly added environment variable will be seen in your User Variables list.
The new setting becomes effective the next time you launch the Siebel Client application.
To permanently change environment variable SIEBEL_LOG_EVENTS in Win NT
- In the Windows Start menu, choose Settings > Control Panel > System > Environment Tab.
- Click the Variable box and set to SIEBEL_LOG_EVENTS.
- Click the Value box and set to <event level>.
- Click Set; then the newly added environment variable will be seen in User Variables list.
To permanently change environment variable SIEBEL_LOG_EVENTS in Windows XP
- In the Windows Start menu, choose Settings > Control Panel > System > Advanced tab.
- Click the Environment Variables button.
- In the User variables area, click New.
- In the Variable name field, enter SIEBEL_LOG_EVENTS.
- In the Variable value field, enter <event level>.
- Click OK to display the newly added environment variable in the User variables list.
