Siebel Remote and Replication Manager Administration Guide > Administering Siebel Remote > How to Set Client-Side Logging >
Archiving
The Archive_number is a positive integer that determines how many log files will be archived. By default, only 10 archived log files are retained and the oldest log file is deleted. To change the archive_number
- Open a DOS Window and change the current directory to the <ClientRootDir>\bin directory.
- Enter the following command:
set SIEBEL_LOG_ARCHIVES=<archive_number>
NOTE: For log files that belong to 1, each execution of the program creates a new log, <program>.log, while archiving the previous versions as <program>_1.log, <program>_2.log, and so on, pushing down the numbers in an increasing order chronologically. Log files that belong to 2 will not be deleted regardless of the value of the SIEBEL_LOG_ARCHIVES variable.
