Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Remote and Replication Manager Administration Guide > Administering Siebel Remote > Monitoring Siebel Remote Operations > About Automatic Notification of Critical ConditionsDuring processing, certain critical conditions can occur on the Siebel Remote server related to the transaction router, transaction processor, or the transaction merger component. You can configure your Siebel server implementation so that, if one of these conditions does occur, a notification alert is generated and an email message is sent to you automatically. The purpose of this notification alert is to reduce the time it takes you to detect and respond to these problematic conditions. The following conditions can generate email notification messages:
The email notification alert feature must be enabled by defining the critical throughput thresholds and related alert notification settings. For information on enabling email notification, see System Administration Guide. |
Siebel Remote and Replication Manager Administration Guide |
