Siebel Remote and Replication Manager Administration Guide > Configuring and Using Mobile Web Client > Siebel Mobile Web Client and Siebel QuickStartSiebel QuickStart is an agent that is preloaded on a mobile user's machine at startup and reduces the time required to launch the Siebel Mobile Web Client. NOTE: Siebel QuickStart can be used with the Siebel Mobile Web Client only, when connecting to the local database or Sample Database. It does not apply to Siebel Dedicated Web Client or Siebel Web Client. Siebel QuickStart is enabled and loaded for the first time from the Siebel application login screen. Siebel QuickStart applies to subsequent instances of the same type of Siebel application session—running the same application as the same user and with the same startup options. The speed increase provided by QuickStart does not take effect on the initial Siebel login. Subsequent logins of the same type of Siebel application session benefit from QuickStart, until the user disables QuickStart. Siebel QuickStart stores the encrypted Siebel user name and password in the siebel.local.client cookie. For additional information about using cookies with Siebel applications, see Security Guide for Siebel eBusiness Applications. NOTE: Users should disable Siebel QuickStart for existing application sessions before enabling it for another application session. Enabling and Disabling Siebel QuickStart
To disable Siebel QuickStart from the login screen
To disable Siebel QuickStart from the system tray
Options for Siebel Icon in the System TrayWhen the Siebel application is running or the QuickStart agent is loaded, an icon appears in the system tray. Right-clicking this icon displays several choices:
Using View Precaching with Siebel QuickStartWhen the QuickStart agent is loaded, views specified using the parameters in the In the [Preload] section, specify the names of the views to be precached as the values for configuration parameters named View1, View2, and so on. For more information about specifying configuration file parameters, see Siebel System Administration Guide. Specifying QuickStart Availability with Siebel PackagerBy default, the siebel.exe program has Siebel QuickStart available. However, administrators may choose to package client installations with QuickStart unavailable—so the Enable Siebel QuickStart check box does not appear on the Siebel login screen and thus cannot be enabled by end users. When preparing model Siebel client installations to include in packages you create using the Siebel Packager utility, you can disable Siebel QuickStart. To do this, rename or remove the siebel.exe program and then change the name of siebel1.exe to siebel.exe. For more information on using the Packager utility, see Going Live with Siebel eBusiness Applications. QuickStart and AutoStopDB Configuration ParameterWhen you are using Siebel QuickStart, you may also decide to set the configuration parameter For more information about the AutoStopDB parameter, see Siebel System Administration Guide. |
| Siebel Remote and Replication Manager Administration Guide |
