Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server > Generating a New Database Template > Distributing Database Templates to Siebel Remote ServersIf your deployment includes multiple Remote servers, this section describes how to distribute the database templates. You can distribute it to each Siebel Server by running the distmpl .bat file. This file creates the proper directory on each Siebel Server and copies the database template into the directory. Alternatively, run the generate new database component at each Siebel Remote server to create the necessary database template file.
Example 1Enter: where Example 2where |
Siebel Remote and Replication Manager Administration Guide |
