Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Remote and Replication Manager Administration Guide > Siebel Remote Concepts > Siebel Remote Server Components > Synchronization ManagerThe Siebel Remote server starts a Synchronization Manager task for each incoming synchronization request from a Mobile Web Client. For each request, the Synchronization Manager:
Each Synchronization Manager task services only one Mobile Web Client at any one time, but many synchronization tasks can be started concurrently. This behavior is configured by a Synchronization Manager parameter called Max Task. The Synchronization Manager component must be enabled for Siebel Remote mobile users to be able to connect to the Siebel Remote server for synchronization. Synchronization Manager tasks start automatically; you do not need to start tasks for this component manually. NOTE: The Siebel File System parameter for Synchronization Manager component determines the file system location for Mobile Web Clients. |
Siebel Remote and Replication Manager Administration Guide |
