Siebel Remote and Replication Manager Administration Guide > Siebel Remote Concepts > Using Siebel Remote >
About Generating a Database
If you are setting up a Siebel Remote server for the first time, you will also need to generate a new database template, that is, a database that contains no end user data, but which has the specific structure required for use with Siebel applications. You can generate a new database template by running the Generate New Database component. On the Application server, this component creates a template and places it in the dbtempl directory on the Application server. For information on generating a new database template, see Generating a New Database Template.
