Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Remote and Replication Manager Administration Guide > Extracting Databases for Mobile Web Clients > Database Extraction for a Mobile Web Client > Configuring the Remote Server for Local Database Password EncryptionYou can enable RSA SHA-1 encryption, a one-way hashing algorithm, to be applied to the local database password before it is passed to the local database for authentication. Encryption adds a layer of security by disconnecting the password stored in the local database from the unencrypted password entered by the user. Encryption of the local database password requires configuration on the Remote server and on the Mobile Web Client.
For information about doing a database extract, see Database Extraction for a Mobile Web Client. For a list of all database extract component parameters, see Parameters of the Database Extract Component. |
Siebel Remote and Replication Manager Administration Guide |
