Siebel Remote and Replication Manager Administration Guide > Setting Up Mobile Web Clients > Setting Synchronization Preferences > Enabling Encryption for Synchronization NetworkingTo use encryption, both the server and the client must enforce encryption in their connection parameters. If these parameters do not match, connection errors will occur.
Siebel eBusiness Applications use MSCRYPTO or RSA to encrypt data traffic between the server and the Mobile Web Client. It is configured at the component level for replication with these clients and the server. It is not used to encrypt the local database nor the data in it. Also, it is not used for communication with the database. NOTE: Secure Sockets Layer (SSL) is not a supported encryption method for synchronization. |
| Siebel Remote and Replication Manager Administration Guide |
