Siebel Remote and Replication Manager Administration Guide > Setting Up Mobile Web Clients > Routing Rules and Dock Objects > Routing RulesRouting rules are SQL statements that Transaction Router and or Database Extract use to evaluate what records should be routed to each mobile user. Siebel releases can include more than a thousand active routing rules. They are designed to accomplish the following:
The types of routing rules are the means to implement these requirements. NOTE: Changes to routing rules provided by Siebel Systems require Siebel Expert Services working in conjunction with Siebel engineering. However, for extension tables generated using Database Extensibility, routing rules can be generated using a wizard provided within Siebel Tools. |
| Siebel Remote and Replication Manager Administration Guide |
