Siebel Remote and Replication Manager Administration Guide > Setting Up Mobile Web Clients > Limiting Views Available to Mobile Web Clients >
Using the Responsibilities View
The Responsibilities view within the Administration - Application screen includes a Responsibilities list and two subordinate lists:
In this view you can do the following:
- Adjust the Local Access flag—turn it off or turn it on.
- Add views to a responsibility.
- Read the Routing Model assigned to a user.
NOTE: To assign users to routing models, you would choose Navigate > Site Map > Administration - Siebel Remote > Mobile Clients from the application-level menu, and proceed as described in Registering a Mobile Web Client.
- Add users to a responsibility.
The procedure below describes how to limit the visibility of views for mobile users assigned to the routing models listed at the beginning of this section. To limit the visibility of views for Mobile Web Clients
- Determine the views a mobile user does not need.
- From the application-level menu, choose Navigate > Site Map > Administration - Application > Responsibility List > Responsibilities, and select the responsibility with a view this mobile user does not need.
- In the Views list, select the view this mobile user does not need.
- Clear the Local Access check box to remove the check mark.
- Repeat Steps 3 and 4 for all the views the mobile user does not need that are associated with this responsibility.
