Siebel Remote and Replication Manager Administration Guide > Administering Siebel Replication Manager > Managing Security and AuthenticationReplication Manager uses the administrator's user name and password to log on to the Parent node. During this process, it authenticates against its parent node, usually the HQ node. It does this according to the Authentication Method set in the Synchronization Manager Component of the parent node. For more information about the Authentication Method parameter, see Table 9. It is recommended that the administrator user name and password be the same on the HQ database and the regional databases. The Regional Application Servers and srvrinit use the administrator database login. To change the administrator password for Replication Manager
| Siebel Remote and Replication Manager Administration Guide |
