Siebel Remote and Replication Manager Administration Guide > Troubleshooting Remote and Replication Manager > Troubleshooting Synchronization Manager >
FAQ: Long Initialization/Synchronization Times
When you receive the CSSSISDockFgetACKMsg msg error during initialization or synchronization there are basically two cases to differentiate:
- You are working in a network environment.
In this case the error might have occurred due to very heavy network traffic.
- You are working over a phone line.
In this case one possible reason could be an unstable telephone line.
- If possible, you should try different telephone lines.
- Another reason could also be a bad modem, either on the client side or the server side.
- In either case, work with your IT department to troubleshoot the problem.
