Security Guide for Siebel Business Applications > Communications and Data Encryption > Configuring Data Encryption >
Upgrade Issues for Data Encryption
The Siebel Strong Encryption Pack upgrades Siebel Business Applications to 128-bit, 192-bit, or 256-bit encryption. For more information, see About Siebel Strong Encryption Pack. Supported data encryption upgrade scenarios are outlined in the following list:
- Upgrade to 128-bit RC2 encryption from the following:
- No encryption
- Standard Encryptor encryption (based on mangle algorithm)
- 56-bit RC2 encryption
- Upgrade to 128-bit AES encryption from the following:
- No encryption
- 128-bit RC2 encryption
- Upgrade to 192-bit AES encryption from the following:
- No encryption
- 128-bit AES encryption
- Upgrade to 256-bit AES encryption from the following:
- No encryption
- 192-bit AES encryption
