Security Guide for Siebel Business Applications > Security Adapter Authentication > Implementing LDAP/ADSI Security Adapter AuthenticationThis section provides instructions for implementing LDAP/ADSI security adapter authentication. To provide user access to a Siebel application implementing LDAP/ADSI security adapter or Web SSO authentication, the Siebel application must be able to retrieve the following: Task OverviewYou must perform the following tasks to set up a typical LDAP/ADSI security adapter authentication architecture:
The LDAP/ADSI Configuration Utility can modify parameter values on the Name Server. You can also modify Name Server parameters using Siebel Server Manager. For Developer Web Client deployments, the LDAP/ADSI Configuration Utility can modify parameter values in application configuration files, such as uagent.cfg for Siebel Call Center. You can also modify configuration files by editing them manually. For more information about using the LDAP/ADSI Configuration Utility, see Using the LDAP/ADSI Configuration Utility. For more information about security-related configuration parameters, see Configuration Parameters Related to Authentication. Issues for Developer and Mobile Web ClientsSpecial issues apply for authentication for deployments using Siebel Developer Web Client or Mobile Web Client:
| Security Guide for Siebel Business Applications |
