Using your default text editor, edit the following parameters in the [ActuateReports] sections.
[ActuateReports]
EnableReportServer = TRUE
ReportServerHost = Valid formats for this parameter are:
- If using an IP Address to refer to the Reports Server Host, then you need to include the Encyclopedia volume name for this parameter.
IP Address:Port Number/Encyclopedia volume name (example: 1.160.10.240:8000/volume1)
- If the Reports Server Host name is different from the Encyclopedia volume name, then the Encyclopedia volume name must be included for this parameter.
ReportServerHost:Port Number/Encyclopedia volume name (example: server1:8000/volume1)
- If the Reports Server Host name and the Encyclopedia volume name are the same, then the Encyclopedia volume name does not need to be included for this parameter.
ReportServerHost:Port Number (example: server1:8000)
NOTE: By default, if the Encyclopedia volume name is not specified, it is assumed to be the same as the ReportServerHost.
ReportCastHost = No longer required
ReportCastDomain = No longer required
ProtocolName = Name of protocol to use for viewing reports (example: HTTP)
RoxDir = /Siebel Reports/
ConnectString = Connect string for an Application Object Manager (where load balancing is not deployed) is:
siebel.TCPIP.none.none://SiebelServerHost:SCBPort/EnterpriseServerName/XXXObjMgr_language
where:
siebel.TCPIP = Networking protocol
none.none = The encryption type and compression type
- SiebelServerHost = Name of the machine on which the Siebel Server is installed
- SCBPort = Listening port number for the SCBroker component (default is
2321)
- EnterpriseServerName = Name of your Siebel Enterprise Server
- XXXObjMgr_language = Type of Object Manager and Language Pack for the Siebel Business application you are installing, for example:
SCCObjMgr_enu for Siebel Call Center Object Manager for U.S. English
PManagerObjMgr_enu for Siebel Partner Manager Object Manager for U.S. English
