Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing the Siebel Reports Server > Verifying Actuate iServer Component InstallationYou should verify that the Siebel Reports Server and its components were successfully installed before continuing with the postinstallation tasks for the Siebel Reports Server. To verify installation of the Actuate iServer and Management Console for Siebel
To confirm a successful installation of Actuate Active Portal JSP
NOTE: Because the Single Sign-On feature is implemented during the Reports Server installation, you will not be able to directly access the Active Portal JSP beyond the home page. To confirm a successful installation of Reports View Adapter for Siebel
NOTE: Because the Single Sign-On feature is implemented during the Reports Server installation, you will not be able to directly access the Reports View Adapter for Siebel beyond the home page. Setting Actuate iServer ParametersThe Reports Server administrator should set the Actuate iServer parameter Factory services properties - Number of Requests Before Recycling Processes to 100 to avoid memory leaks. For instructions on how to modify this Actuate iServer parameter, see the Administering Actuate iServer System manual in the Actuate folder of the Siebel Business Applications Third-Party Bookshelf. NOTE: To set parameters for Actuate iServer, open the Actuate Management Console, log in to System Administration, select a Server, and select the Advanced tab. |
| Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools |
