Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing the Siebel Server >
Configuring the Siebel Server for Automatic Start on AIX
If, during installation, you elected automatic restart of the Siebel Server, you need to complete the procedure that follows to enable it. To configure Siebel Server to start automatically
- Navigate to $SIEBEL_HOME/bin.
where:
- $SIEBEL_HOME = The installation directory for the Siebel Server
- Using any text editor, open the file
siebel_server, and edit the database environment variable as described below:
Oracle
- Uncomment the line
#ORACLE_HOME=.
- Enter the location for
$ORACLE_HOME.
#export ORACLE_HOME.
- Add the following two lines:
TNS_ADMIN=$tns_admin
export TNS_ADMIN
Ask your database administrator for the value of $tns_admin.
DB2 UDB
- Add a line to execute
db2profile, for example:
. /home/db2v8aix/sqllib/db2profile
Ask your database administrator for the location of db2profile.
- Save and close the file.
- Log on as root and execute the following command on a single line:
mkitab "start_server:2:wait:su - SIEBEL_ACCOUNT -c \"$SIEBEL_HOME/bin/siebel_server start\""
where:
- SIEBEL_ACCOUNT = The user account installing the Siebel products
- Verify whether or not the file /etc/rc.shutdown exists. If it does not exist, create it and change the permissions:
touch /etc/rc.shutdown
chmod 744 /etc/rc.shutdown
- Edit the file /etc/rc.shutdown to add the following command:
/usr/bin/su - SIEBEL_ACCOUNT -c "$SIEBEL_HOME/bin/siebel_server stop"
where:
