Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Preparing for Installation > General Considerations in Planning Your Siebel Deployment > File and Directory Naming ConventionsUse lowercase for all filenames, directory names, path names, parameters, flags, and command-line commands, unless you are instructed otherwise. Directory names or filenames may not contain special characters, such as apostrophes, accents, number (pound, or hash) signs, ampersands, or spaces. For Windows server installs, spaces are not allowed; spaces are allowed on Windows client installs. Underscores are acceptable. How This Guide Refers to Your Installation DirectoriesThis guide uses the following variable-naming conventions to refer to the installation directories either created by the installers or to which users navigate to access files and executable programs. $SIEBEL_ROOT. Generally, this refers to the main directory in which software for each Siebel Server Enterprise entity has been installed. The installers for the UNIX Enterprise Server components install into the top-level directory /siebel by default, though the actual directory where you install is likely to be different, such as /export/home/siebel. Generally, this directory is what $SIEBEL_ROOT represents in this book. However, $SIEBEL_ROOT may also represent the value of the SIEBEL_ROOT environment variable, which usually corresponds to a component-specific installation directory, such as /export/home/siebel/siebsrvr for Siebel Server. $SIEBEL_HOME. The installation or root directory for Siebel Business Applications software in general, or the Siebel Gateway Name Server or the Siebel Server, depending on the context. Many scripts contain variables with this name; its meaning is most often derived from the context. $SIEBSRVR_ROOT. The installation or root directory for Siebel Server. $SIEBEL_SERVER_ROOT. This term is sometimes used within executable programs, such as the $SIEBEL_GATEWAY_ROOT. The installation or root directory for Siebel Gateway Name Server. SWSE_ROOT. The directory into which you install the Siebel Web Server Extension (SWSE). SIEBEL_CLIENT_ROOT. The directory into which you install the Siebel Mobile Web Client or Siebel Developer Web Client. SIEBEL_TOOLS_ROOT. The directory into which you install the Siebel Tools Client. |
| Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools |
