Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Verifying Your Server Environment > Running EVT in Query ModeEVT can also be run in query mode. This mode is intended to interface with other utilities that need to query the installation for information. To run in query mode, you must use the NOTE: In query mode, EVT ignores all other options except the The query string consists of name The output of EVT in this mode is either Example% evt -q "Checkname=VAR+ParamName=SIEBEL_ASSERT_MODE+ParamValue=0" This command returns Example% evt -q "Checkname=UNDEFVAR+ParamName=SIEBEL_ASSERT_MODE" This command returns |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
