Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Database Server and Configuring the Siebel Database > Configuring the Siebel Database on the RDBMSConfiguring the Siebel Database requires these tasks:
You will perform configuration tasks using the Database Server Configuration Wizard, which is available on the machine on which you installed the Siebel Database Server. CAUTION: In an upgrade environment, you install the Siebel Database Server on the Siebel Server, following the procedure in Installing the Siebel Database Server on the Siebel Server, but you do not perform any of the other tasks mentioned in this chapter. For more information, see About Installing in Upgrade Environments. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
