Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Reports Server > Postinstallation Tasks for the Siebel Reports Server >
Enabling the Siebel Reports Server with the Siebel Developer Web Client
This section describes how to modify configuration files, such as siebel.cfg, on the Developer Web Client to enable the Siebel Reports Server.
NOTE:  This content is provided for troubleshooting purposes only. Using reports with the Developer Web Client is not supported for end user deployment.
To configure the Siebel Reports Server with the Siebel Developer Web Client
  1. Navigate to the BIN\language subdirectory of your Siebel Business Applications installation directory.
    where:
    • language = The Siebel code for the Language Pack you installed; for example, ENU for U.S. English.
  2. Locate and open the appropriate configuration (CFG) file.
  3. Using your default text editor, edit the following parameters in the [ActuateReports] sections.
    [ActuateReports]
    EnableReportServer = TRUE
    ReportServerHost = Valid formats for this parameter are:
    • If using an IP Address to refer to the Reports Server Host, then you need to include the Encyclopedia volume name for this parameter.
    IP Address:Port Number/Encyclopedia volume name (example: 1.160.10.240:8000/volume1)
    • If the Reports Server Host name is different from the Encyclopedia volume name, then the Encyclopedia volume name must be included for this parameter.
    ReportServerHost:Port Number/Encyclopedia volume name (example: server1:8000/volume1)
    • If the Reports Server Host name and the Encyclopedia volume name are the same, then the Encyclopedia volume name does not need to be included for this parameter.
    ReportServerHost:Port Number (example: server1:8000)
    NOTE:  By default, if the Encyclopedia volume name is not specified, it is assumed to be the same as the ReportServerHost.
    ReportCastHost = No longer required
    ReportCastDomain = No longer required
    ProtocolName = Name of protocol to use for viewing reports (example: HTTP)
    RoxDir = /Siebel Reports/
    ConnectString = Connect string for an Application Object Manager (where load balancing is not deployed) is:
    siebel.TCPIP.none.none://SiebelServerHost:SCBPort/EnterpriseServerName/XXXObjMgr_language
    where:
    • siebel.TCPIP = Networking protocol
    • none.none = The encryption type and compression type
    • SiebelServerHost = Name of the machine on which the Siebel Server is installed
    • SCBPort = Listening port number for the SCBroker component (default is 2321)
    • EnterpriseServerName = Name of your Siebel Enterprise Server
    • XXXObjMgr_language = Type of Object Manager and Language Pack for the Siebel Business application you are installing, for example:
      • SCCObjMgr_enu for Siebel Call Center Object Manager for U.S. English
      • PManagerObjMgr_enu for Siebel Partner Manager Object Manager for U.S. English
