Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Web Server Extension > Postinstallation Tasks for the SWSE >
Supporting ASP Pages and Siebel Applications on the Same Web Server
In general, it is recommended not to host ASP pages and Siebel applications on the same Microsoft IIS Web server. If you want to deploy both ASP pages and Siebel applications on the same Web server, you must isolate the ASP pages from the Siebel applications. Doing so may reduce performance and scalability.
- On IIS 6.x, place all Siebel applications (virtual directories) in an Application Pool that is separate from the Application Pool containing the ASP pages.
- On IIS 5.x, set Application Protection to High (Isolated) for each Siebel application (virtual directory) and for the ASP pages.
For more information about supported versions of Microsoft IIS, see System Requirements and Supported Platforms on Siebel SupportWeb.
