Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Web Server Extension > Troubleshooting SWSE InstallationThis section provides suggestions for troubleshooting problems you may encounter when installing the SWSE. Problem: After installation, when launching the Siebel Web Client, a message appears, stating: Cause: Virtual directories were not installed or configured properly. Solution: Use the following procedure to resolve the problem.
Problem: Your Siebel application hangs or times out. Cause: Appropriate parameters are not available within the [default] section of the eapps.cfg file for the Siebel Business Application. Solution: Make sure that the defaults section of the eapps.cfg file contains valid username, Problem: After stopping the IIS Administration Services, an error message appears: The service did not respond to the start or control request in a timely fashion Cause: Stopping the IIS Administration Service from Component Services in the Windows Control Panel creates an error. Solution: Open a DOS command window and issue the following command to release all resources used by services, such as inetinfo.exe and dllhost.exe: If, after doing this, you still cannot start the Siebel applications, you must restart the machine. Problem: Inability to access the Siebel Web Client. The browser status bar may display errors, such as Cause: The IWAM and IUSR user accounts do not have proper permissions to the SWSE_ROOT\public\lang directory. Solution: Stop the Web server. Grant the IWAM and IUSR user accounts write permission to the SWSE_ROOT directory and its subdirectories, including SWSE_ROOT\public\lang. Restart the Web server. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
