Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Web Server Extension > Postinstallation Tasks for the SWSE > Reviewing the Installation for the SWSEReview the physical and virtual directories created during installation of the Web Server Extension on the Web server host to familiarize yourself with the locations of files such as the eapps.cfg configuration file. Verifying Physical Directories on the SWSE InstallationThe following list shows some of physical directories and files created after you install the SWSE on the Web server. Some of these folders are not created until the first login. In the list, language represents languages you have installed, such as ENU for U.S. English. _uninst. Contains files required for uninstallation of the product. ADMIN. Contains the file swseapps.scm, which is used during installation. This file launches the dialog boxes used during configuration of the Siebel Business Applications. BIN. Contains the SWSE configuration file (eapps.cfg) and the libraries needed for the SWSE functionality. ISSRUN. Contains the files for Customer Order Management CDA run time. CDA run time is used most commonly for Siebel Advisor and sometimes for catalogs or product configuration. LOCALE. Contains resource files with information about any run-time errors. LOG. Reports communication errors between the SWSE and the Application Object Managers in the Siebel Servers. PUBLIC. Each language-specific subdirectory contains the default HTML file (default.htm) used to redirect the browser to the SWSE and subdirectories of the Siebel Server. Verifying Virtual Directories on the Web ServerVirtual directories are installed on the Web server for each installed Siebel Business Application. For example, there is an eservice_enu directory for Siebel eService using U.S. English (ENU). To verify the virtual directories
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
