Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing Siebel Mobile Web Clients > Postinstallation Tasks for the Siebel Client >
Configuring the Siebel Client When Siebel VB or Siebel eScript Is Not Licensed
The default configuration files for the Siebel client have Siebel VB or Siebel eScript enabled. This is done by setting the parameter EnableScripting to TRUE. If this parameter is TRUE, but you do not have either Siebel VB or Siebel eScript licensed, the client does not start. An error message is returned, indicating that you must turn off Siebel VB or Siebel eScript before running the client. To configure Siebel client when Siebel VB or Siebel eScript are not licensed
- Set
EnableScripting to FALSE in the configuration file used by your Siebel client configuration. This configuration file resides in the directory SIEBEL_CLIENT_ROOT\bin\LANGUAGE.
