Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing Siebel Tools > Postinstallation Tasks for Siebel Tools >
Verifying the Siebel Tools Directory Structure
The following minimum directories are created for the Typical selection for a Siebel Tools installation. These directories, the files and subdirectories they contain, and various other files are created in the directory you specified during the installation, such as D:\Program Files\Siebel\7.8\Tools.
actuate
Actuate-related files for generating and running reports.
afc
Actuate Foundation Class files.
bin
Actuate binary files.
bin
All binary files (.exe, .dll, .cfg, .dsn, .enu, .bat), configuration files, and user preference files.
language
Language-specific dll files.
dll
Siebel Tools program library files.
bin
Siebel Tools binary files.
exe
Siebel Tools executable files.
classes
Java code files.
examples
examples\src
examples\src\com
examples\src\com\siebel
examples\src\com\extra
examples\src\com\integration
examples\src\com\integration\mq
Examples of Java code files.
examples\src\com\integration\servlet
ddktempl
Dynamic Developer Kit (DDK) files. For more information, see the Siebel Web UI Dynamic Developer Kit Guide.
help
Siebel Tools help files.
language
Help files for the language you installed.
local
The local, extracted database.
files
Local file attachments.
inbox
Not used for Siebel Tools.
outbox
locale
Language-specific files.
log
Log files from Siebel Tools operations.
msgtempl
Message files.
objects
Location of the siebel.srf file, the compiled definition file used by Siebel Tools. This is also the default location for SRF files created using the Siebel Tools object compiler.
NOTE:  Monitoring of any SRF file by virus scanning software may significantly degrade Siebel Tools Client performance. If you have virus scanning software installed on your computers, you should configure it to skip SRF files. Because these files are binary data files, the risk of virus infection is low, and so excluding these files from scanning should be acceptable. Alternatively, you may choose to scan SRF files, but less frequently than other files.
public
HTML and graphics files for uploading and cascading style sheet files.
reports
Location of all report files.
language
Version for the language you installed.
reppatch
Location of the XML files used by the maintenance update wizard. All log files generated by the maintenance wizard are also created under reppatch\log.
We use the same folder for configuration of the postupgrade wizard rules and log file generation.
rptsrc
Location of Actuate source files for all reports.
language
language\lib
Report object library (.rol) files.
language\standard
Report object design (.rod) files.
sample
Location where the Sample Database (sse_samp.dbf) is installed, if you installed it.
files
Where the sample file attachments are installed.
inbox
outbox
scripts
Location of Java scripts.
sqltempl
SQL statement fragments used by certain Siebel Tools operations.
temp
Temporary working area.
upgrade
webtempl
Location of Siebel Web Template (.swt) files.
