Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Preparing for Installation > General Considerations in Planning Your Siebel Deployment > Specifying the Locale for Siebel ApplicationsWhen a Siebel application component (Siebel Server, Siebel Tools client, or Siebel Developer Web Client) opens a connection to the Siebel Database, the locale is automatically determined on a per-session basis for the connection. This setting overrides settings that may be defined elsewhere. Customers should not explicitly set the Settings in the Windows Registry affect any software that runs on that machine—except for the Siebel applications themselves. For deployments using an Oracle database, the CAUTION: For development environments, Siebel Business Applications support only binary sort order. Therefore, for Oracle databases, when you are setting the locale for your development environment, either you should not You can explicitly set the locale for a Siebel Server (or Application Object Manager component) to use by setting the Locale Code parameter for the Siebel Server. For more information about creating or configuring this type of locale, see the Applications Administration Guide and the Global Deployment Guide.
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
