Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Preparing for Installation > About Installing Siebel ReleasesEach Siebel Business Applications software release from Siebel Systems has a specific version or release level. Full installations can be performed from any three-digit release, such as 7.8.2. A full installation is your base product installation. The procedures in this book are for performing full installations of the base products. Server products are configured after a full installation, using the Siebel Software Configuration Wizard. Siebel Systems subsequently provides additional releases that can be installed on top of your existing base product installation. Such releases are collectively known as maintenance releases. If you already have a base product installation, a subsequent three-digit release can be installed as a maintenance release. For example, 7.8.3, if available, could be installed on top of an existing 7.8.2 installation. Releases that can only be installed as maintenance releases include Fix Pack releases (four-digit releases, such as 7.8.2.1 or 7.8.2.2) and Quick Fix releases. Typically, no configuration tasks are associated with installing a maintenance release. You generally do not need to run the Siebel Software Configuration Wizard. However, requirements for a given maintenance release, or for using particular supported languages or features, may vary. For details, refer to the applicable Maintenance Release Guide on Siebel SupportWeb. You can set up your installations so that a Fix Pack or Quick Fix release will be automatically installed immediately following a full installation of the base products, in a chained fashion. This type of installation is sometimes referred to as slipstream installation. Before you install the base products, you should note whether maintenance releases are available and consider whether to install them together in this manner. For example, if the current base release level is 7.8.2 and Fix Pack release 7.8.2.1 is available, you can install these releases together, in sequence. All Siebel products used within a given Siebel Enterprise must share the same release level, such as 7.8.2 or 7.8.2.1. NOTE: For detailed information about installing maintenance releases (including slipstream installation) and about the features or other changes provided in the release, refer to the applicable Maintenance Release Guide on Siebel SupportWeb, where it is available. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
