Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring Oracle for Siebel Applications > Guidelines for Overriding Oracle Default Table Spaces for Database ObjectsSiebel Systems provides the option of overriding the default storage parameters for the table spaces in which specific tables or indexes are created. You created these table spaces using the instructions under Guidelines for Creating Oracle Table Spaces. To override these parameters, edit the ddl.ctl file located in the dbsrvr\oracle directory. NOTE: The ddl.ctl file should be modified only by a qualified DBA. For each Siebel object (table or index), you can specify a table space by using the
The following example illustrates the use of the [Object 219] If you use locally managed table spaces and want to change the storage parameters, see your Oracle technical documentation. For an example of overriding the defaults for specific tables and indexes, see Guidelines for Overriding DB2 UDB Default Table Spaces for Database Objects. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
