Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring MS SQL Server for Siebel ApplicationsThis section contains guidelines for obtaining optimal performance from the Microsoft SQL Server database for use with Siebel Business Applications. These guidelines will be useful to a broad segment of customers. However, you should choose values for the parameters described in this guide that reflect conditions in your particular environment. For additional information, refer to Microsoft technical documentation. For additional relevant information, see Overview of Database Configuration. After you have completed configuring your Microsoft SQL Server database, you can perform all Siebel installation tasks, including those described in Installing the Siebel Database Server and Configuring the Siebel Database. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
