Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Uninstalling Siebel Applications > Uninstalling Siebel Reports ServerReview the following procedure when uninstalling the Siebel Reports Server software. NOTE: Do not use Add or Remove Programs from the Windows Control Panel to uninstall the Siebel Reports Server. Use the Siebel Uninstaller to uninstall all products making up the Siebel Reports Server, including the Actuate iServer, Management Console, and Active Portal JSP. Using the Siebel Uninstaller insures that all files are removed correctly. To uninstall Siebel Reports Server
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
