Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel System Administration Guide > Administering Siebel Server Run-Time Operations > Administering Component Jobs > Deleting a Component or Repeating Component JobThis topic describes the procedure for deleting a component job. You can only delete component jobs that have a Status field of Creating. After the component job has been started, you can only cancel the component job. To cancel a component job, see Cancelling a Component or Repeating Component Job. NOTE: You can also delete component jobs by setting the Delete Interval and Delete Units field while creating the component job. See Starting a Component Job for details on setting these fields. After the component job has been started, these fields are read-only. For further information on administering component jobs, see Administering Component Jobs. To delete a component or repeating component job during its creation
Completed component jobs are deleted automatically after a configurable period of time; the fields Delete Interval and Delete Units determine this period and are set, by default, to one week. See Starting a Component Job for details on setting these fields. |
Siebel System Administration Guide |
